Re: 1976 evinrude 9.9 stuck in forward
Welcome to iboats deepsix!
Unless you really rammed the lower unit, I don't see a "tap" as doing anything really bad.
When you shift, can you feel the detents "clicking" in for forward and reverse?
If not, you may want to drop the lower unit and check the shift rod connector. May have popped out.....although I ain't seen one do that.
Be interesting to find out what's going on there. I would drain the lower unit lube and see what, if anything, may be floating around in there.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
