Gear Oil Weight/Type for 1978-9 115HP Evinrude
BlueAxela
The previous owner did not tell me what weight/type of gear oil to use for the lower unit. Should I be using 70W90? I am thinking of using synethic gear oil like Royal Purple for my lower unit.
How about for lower units for any motor? I might be getting a 96 8HP Evinrude, what gear oil do I use in that one?
rickdb1boat
Re: Gear Oil Weight/Type for 1978-9 115HP Evinrude
A high viscosity lube will work in both. A 80W-90 or a 75W-90 synthetic will work fine...
Texasmark
I guess by '78 the electric shifter was a thing of the past which required more like a hydraulic fluid (20w type stuff) to operate over temp.
Mark
