jfwireless
- May 3, 2007
- 6
I have a problem with a 2000 175 HP Ficht outboard.
cylinder number 6 is not working.
When I run Evinrude's diagnostic software the ignition spark checks OK, I can see the spark gap on my tester when I fire cylinder number 6 from the diagnostic program. Spark appears fine.
When I run the injector test I can hear the injector click on all cylinders including cylinder 6..
The engine misfires until I turn off cylinder 6 from the diagnostic software.
The remaining 5 cylinders 1-5 appear to be working fine.
I have no diagnostic codes showing up at all.
Engine has 650 hours on it.
I have changed the coil, spark plug, spark lpug wire, and replaced the primary coil connector as it appeared top be rusty on the cylinder number six coil even though the spark checked out fine.
Any siggestions ???
Jim
Any siggestions ???
Jim
