anthony115merc
- Apr 4, 2007
- 279
my 25 hp merc doesnt like to start i think its a 83/84 2cyl 25hp with quick silver forward controls i have tried to start it and had some trouble trying
i prime till bulb is hard put both switches to run and throttle/gear neutral choke on which is done manually (no solenoid) pull the rope till i can no more its was rebuild 3 yrs ago with 3 runs since i pulled the plugs out and pulled pulls over easy so its not jammed up and when i pull the rope with plugs in its really hard which must be good compression
