  #1
Old June 2nd, 2007, 01:10 AM
Osprey Osprey is offline
Default Any tricks to replacing seals on Teleflex Hydraulic steering on 95 175 Yamaha?
95 175 Yamaha - I plan to replace both end cap seals on a Teleflex hydraulic steering cylinder this weekend. Have the kit with new seals and wrench. This is a saltwater boat.
What are my chances of getting these 12 year old caps to break loose and unthread?
Any tricks to getting them to break loose?
Will I be looking at extensive fluid bleeding after the swap or should it just be a top off?
  #2
Old June 2nd, 2007, 06:09 PM
aleutianwest aleutianwest is offline
Default Re: Any tricks to replacing seals on Teleflex Hydraulic steering on 95 175 Yamaha?
they should come off fairly easy you will loose fluid about a quater cup you might get lucky and only have to refill resivoir but bleeding is easy just time consuming
  #3
Old June 3rd, 2007, 12:30 AM
Project accomplished. Was prepared with the six pound sledge, but both end caps came off just using the provided tool in the rebuild kit. Modified the bleeding procedure a bit, but was able to do it on my own without any special connectors or tubing, just a bottle of SeaStar oil, an empty container for the waste oil and plenty of paper towels. Hardest part was removing the left and right end pieces that connect the stainless cylinder shaft to the motor. This did require a little encouragement from the hammer. Overall an easy project.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replacing a steering wheel on a Teleflex steering system? BoneDigger Boat Topics and Questions (not engine topics) 7 April 10th, 2009 07:31 PM
Mercury teleflex hydraulic steering jeffchis Mercury & Mariner Outboards 4 April 25th, 2006 06:12 PM
Replacing a Hi-Lex steering rack with a teleflex shawhill Boat Topics and Questions (not engine topics) 2 July 13th, 2003 04:47 AM
Replacing a Hi-Lex steering rack with a teleflex shawhill Mercury & Mariner Outboards 2 July 13th, 2003 04:47 AM
hydraulic steering seals leaking bparks1 Johnson & Evinrude Outboards 5 May 25th, 2002 04:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
