What happens if my 1975 9.9 hits a log? Clutches slip?
outboardnut
Hi All
I have a 1975 9.9 that I'm wanting to start using in a shallow river. I'm concerned about what's going to happen when I hit a log. I know this motor does not have a shear pin. Will the prop slip or will I tear out the prop bushing each time I do this.
I uses to bust a half dozen sheer pins a weekend with my old motor.
Windykid
Re: What happens if my 1975 9.9 hits a log? Clutches slip?
You better carry a spare prop...
F_R
Yes, the rubber hub in the prop absorbes impacts to protect the drive train when grinding up stumps and rocks. The hub can take it but the blades take a beating.
jtexas
Do you run with the tilt lock engaged? If so, try disengaging it - if you hit an obstruction head-on, the motor should kick up out of the water.
jimmbo
Does't that engine have a shallow water drive setting? Flip the lock/unlock lever on the side of the engine to unlock, tilt the engine about half way up. You should heard click as a bracket moves into postion. Lower the engine, the bracket should contact the tilt pin and hold the engine at a tilted angle. To lower move the lock lever to lock, lift the engine a bit then lower it. it should then go all the way down.
