  #1
Old May 31st, 2007, 11:14 PM
godofthewaves godofthewaves is offline
Default 1969 evinrude 85hp clicking in neutral and reverse
My 1969 evinrude 85hp had gear case rebuilt last summer with shift solenoids and shaft replaced.
Suddenly I lost reverse and gear case click on reverse and neutral. Neutral work but clicks in lower part. Forward is fine.
Any help would be great.
Stef
  #2
Old May 31st, 2007, 11:21 PM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: 1969 evinrude 85hp clicking in neutral and reverse
Check your gearube if you already haven't. You should be getting 12v+ to the green wire in Neutral, and both the green and blue wires in Reverse. Make sure you're using Premium Blend gearlube and not conventional gearlube. I hear that ATF works too, though I'm skeptical.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old May 31st, 2007, 11:22 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Check the gearlube as it's possible that a leak exists. If low on lube, use only Premium Blend, also know as Type C, available at your dealership.
(Hydro Electric Shift)
(J. Reeves)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Preminum Blend" lube, commonly called "Type C". (A thinner lube)
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
http://stores.ebay.com/Evinrude-John...tc?refid=store
  #4
Old May 31st, 2007, 11:25 PM
gear lube is fine. This engine stays on forward by default and switches to neutral or reverse only when powered. I am scared to run in in neutral or reverse because of the clicking. Any thoughts?
Stef
  #5
Old May 31st, 2007, 11:29 PM
When I talked to mechanic he said solenoid is bad, sound to me reverse spring has jumped. If I start engine and run in neutral or reverse I am scared to hurt it.
Stef
  #6
Old June 1st, 2007, 04:07 PM
kauboy kauboy is offline
If your mech is right, and the solenoids are bad, thats quite a pickle. The replacement kit is $164 and not many places can get them. I know there is a place up in Seattle that still has them to sell to distributors.
I found mine on eBay for $15. The lady had no idea what they were. That was very lucky. You might get lucky too, just keep looking.
First, before you jump to that conclusion, do some testing.
You can test the continuity of the solenoids with a multimeter. Disconnect the blue and green wires at the powerhead and kick your multimeter to the ohms setup. Stick the red probe on the wire (pick one) leading down to the solenoids and the black probe to a good ground on the engine. You should read 5~7ohms. Do this to the other wire and look for the same reading.
Be extra positive that you have a good ground. A bad one will make you think both solenoids are bad. I used a screw on the starter solenoid I think...
If either solenoid shows up as 0 ohms, you still may not be in hot water. The next thing to do is to drop the lower unit and visually inspect the wiring. It turned out that my wire was broke when I finally dropped the unit. But I had already bought the solenoids, so I replaced them anyways.
You may get lucky and just have an easy to mend break in the line.
If both solenoids show a reading of 5~7 ohms, I'd start looking for a different cause. Maybe your not getting enough juice down there to fully actuate them. That might be the clicking.
With the batt plugged up, the ignition set to "On" but don't start the engine, and the gear buttons set to the "Forward" position, check the wires coming from the powerhead that would hook to the ones going down to the solenoids. The one for the green wire should have 0v, and the blue one should have 0v also. Again, you'll need a good ground.
Then push the button for "Neutral" and check them again. The green should show +12v, and the blue should show 0v. Now push the "Reverse" button and check the wires. Both green and blue wires should have +12v.
If any of these readings are bad, you have a break or a short somewhere. If any of the readings are less than +12v but greater than 0v, you need to start finding where the voltage loss is occurring.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 65 HP Evinrude (No Reverse or Neutral) ncsu2010 Johnson & Evinrude Outboards 2 April 3rd, 2007 06:26 PM
1969 Evinrude 85 hp, locked in foward, lost neutral & reverse philippe546 Johnson & Evinrude Outboards 4 June 19th, 2006 10:57 AM
1978 85hp Evinrude - clicking at prop cfcajun Johnson & Evinrude Outboards 0 April 11th, 2005 09:24 AM
1969 85hp no reverse or neutral !! HELP ! safaritom Johnson & Evinrude Outboards 2 November 29th, 2003 07:29 AM
1969 johnson outboard motor wont go into neutral or reverse Nathien Johnson & Evinrude Outboards 6 August 30th, 2003 02:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
