  #1
Old May 31st, 2007, 10:42 PM
reeled wicked reeled wicked is offline
Default First Post Yamaha buzzer
Well here goes I have searched for an hour or so on this topic, with out much luck. My 88 yamaha 200 buzzer goes off, but all three arrows on the multifunction gauge flash I thought at first it was an overheat problem, and repaced all cooling compenents including cleaning of water jackets and new head gaskets, water pump, thermostats, and poppet all yamaha parts and again all three arrows light up (blink) let the boat sit a while and goes away. Am I focusing on the wrong Idea. Meaning oil related instead of overheating.
I just bought the boat, and this motor had a bad powerhead, I replaced with a used one and (This may sound dumb.) Have had problems with the precision blend system, so until I have enough money I have been just adding oil into the tank on top of the motor, (very short trips on jordan lake here in North Carolina.) as to not run out of oil. If anyone could help me with what these three blinking arrows mean (All three blinking at one time repeatedly with audible alarm.) I would greatly appreciate it. Thanks Ron Sergeant, Clayton Nc.
  #2
Old June 1st, 2007, 12:15 AM
sc_shane's Avatar
sc_shane sc_shane is offline
Default Re: First Post Yamaha buzzer
I'm definitly not a mechanic by any means, but is there any oil in the oil injection tank? To me, this sounds like the sensor is sending a signal that there's no oil in the tank, and wants to shut down. Just a guess. Maybe you can bypass that tank level sensor? or cap off the oil intake but leave the tank full of oil? Just a thought...
__________________
--=* If you can carry the cooler yourself, go get more beer!!! *=--
1991 Crest 25' Pontoon
1989 Yamaha 90HP
2000 Chevy Tahoe Z71 4x4 V8
  #3
Old June 3rd, 2007, 01:13 AM
yamamarinetech40 yamamarinetech40 is offline
That's sorta right....the sensor in the engine's tank say's"I'm gettin oil" while the remote tank says that that's impossible, cause 'I don't have any to send", you've just confused the system is all, the three flasher's are designed to tell you this....there is no problem with warning sysem indicated....why did you skip remote tank, not pumping? There is a filter on bottom of tank(very small), common problem for no pumping....
  #4
Old June 4th, 2007, 08:38 AM
Ray Neudecker Ray Neudecker is offline
You need to trouble shoot and repair the problem to stop the lgihts flashng.
The tank not transfering the oil to the engine mounted tank is normally caused by a wiring problem or a clogged filter in the boat mounted tank. There have been many posts detailing the trouble shooting process. Use the search function to find and follow them.
  #5
Old June 4th, 2007, 10:44 AM
sc_shane's Avatar
I figured I was on the right track. Best of luck to ya. The guys on these forums are awesome! Return here if you have any more questions - the only dumb question is the one not asked!
__________________
1989 Yamaha 90HP
  #6
Old June 7th, 2007, 09:56 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
shoot me an PM, i have the dealers training trouble shooting guide
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #7
Old July 4th, 2007, 06:14 PM
waterbill waterbill is offline
I had a similar problem with my multifunction gage showing all three levels of oil flashing at the same time. Turned out that the one lead which goes to ground from the in-tank oil level sender had a bad ground. Try disconnecting the ground and cleaning it up and reconnecting it. That took care of my simultaneous flashing oil level indications; However, the overheating problem turned out to be a bad head gasket.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Oil Buzzer - '86 Yamaha 90 hp PenleyFace Yamaha & Suzuki Outboards 3 August 13th, 2005 07:21 PM
Yamaha oil buzzer igofishn Yamaha & Suzuki Outboards 10 April 25th, 2005 05:24 AM
'92 Yamaha 150 buzzer problem stansmith Yamaha & Suzuki Outboards 7 June 10th, 2004 06:40 PM
Help! Yamaha buzzer won't stop... smanter Yamaha & Suzuki Outboards 3 December 6th, 2003 05:16 AM
85 Yamaha 90 HP Warning Buzzer ? Help !? starcraft Yamaha & Suzuki Outboards 4 May 19th, 2002 05:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
