Acquired this motor recently to use with a sailboat. Replaced water pump and spark plugs. starts easily but does not run long before it stalls out. If I squeez the fuel hose bulb it accelerates slightly and continues to run a bit longer. This was tested in a large garbage can filled with water with motor on sawhorse and gas tank on the ground (about 2 feet vertically). Also, does not idle smoothly. It has both lean adjust knob and idle speed knob.
I would appreciate any suggestions or thoughts.
Thanks,
Thanks,
