Re: Paint Types?
its all the prep that makes a paint job good. if you want a great looking paint job, do all the prep work ( the toughest job of all ) and use a sprayer. the primer will allow the new paint to bond to something. the last boat i did i used the roll and tip method - whereas i think it tourned out very nice, it cannot compare to the finish that spraying can do....either one works, it really comes down to how much work do you want to put into it and how much do you want to spend? ( assuming you do not already own a sprayer ).
I agree with you on every point aside the results of tipping & rolling, It is very easy to do with just a bit of practice and the result's will be as good spraying.
If you would have a lot of tight corner's or small edge's yes spraying will be eaiser, however if you have the appropriate roller's (size) it can be done with just a bit of patience.
Perhap's you greatest challenge will come from air borne contaminate's (dust) taking away from a great finish..
I have tried to use a sprayer for perfection, but could not get the paint to atomize fine enough to level properly, and if reduced down to a point that it would flow or atomize corecctly, the results were a orange peel. And probably due to the equipment or lack of experience with the proper solvent's
One of the first thing's i experienced was acetone's inability to cut all the wax off my boat. I have been told by Interlux and a few body shop manager's that it flashes to quicky to get it all, and fisheye's are the result's or tiny pinhole's
After a bath with Acetone and then Xylene and Sherwin William's wax remover (overkill yes but repeat sanding is worse) i sanded the hull down with 180 or ruffed it up. Two coat's of Prime Kote ( sparyed) and sanded them down with 180 again and wiped down with Xylene again.
Using a 7" foam roller i put a lift film of Perfection on (reduced by 2333n @ 15%) in three foot area's, went back and tipped it with a very fine brush i picked up @ Sherwin Willam's, in my mind i would describe tipping as blending paint, it required a bit of practice for me at least and leaves no trace of brush mark's
After the first coat, i again sanded it down with a 320 grit paper and wiped with xylene and repeated the process. I cannot stress how important it is to use a light coat
on application's, it very tough to get right i finally took a old mirrior and practiced till i got it right, that is rolled it, then blended it and watched for sag's
I still have one more coat to go, the pic's you see are with two coat's and they do have some lint contamination in them, dunno if i will find a way around thas issue
Notice the brush it make's a big difference on how well the paint tip's or blend's...........Just a opinion your milage may vary..
Opp's that is Interlux Perfection, for me it was quite a bit harder to get right than than there Bright Side's but both paint's give a great finish, Perfection is said to be a harder finsih and it does really shine or reflect quite a bit better than Bright Side's but then again Bright Sides was by far eaiser to apply and still a great finish very good stuff...
http://s99.photobucket.com/albums/l284/Tail_Gunner_2006/?action=view¤t=1178131338.pbw
