Trim and Tilt Trials
dnotari
I own a Memphis Arrow Glass with a Mercruiser 120 (1967).
My Stern Drive won't stay in the up position. I have bleeded the lines, replaced hydraulic hoses, cleaned out the resevoir and replaced all "O" Rings. I am not sure what to do next. Some say "check valve failure", others say "Trim Cylinders", others say give me lots of money and I will tell you.
Any Ideas? :mad:
Re: Trim and Tilt Trials
It's probably the Valving in the Pump,......
If a cylinder was leaking by, the other 1 should hold up the drive......
