smoking
peteg
I have a 1999 150 hp johnson ocean pro, at the end of last season i noticed that i was have a harder time starting and excessive smoke ( blue ) on first start up of the day, when the motor is running i have no problem with it, good rpm and and very little smoke at all, when i pump up the fuel bulb it get very hard, after start up it is a little softer, last year i put a micron filter on the fuel, when i went to start it up this season it gave me a hard time starting when it did it smoke a long time and it look like oil streaks out the exhust, there was also oil in the cowl, any help would be greatful .... Pete
WillyBWright
Re: smoking
Take that filter out of the system. Your motor is having too hard of a time pulling gas, but still pumping full oil volume.
Dhadley
Re: smoking
Ditto. Anytime there is a fuel restriction the pump will pull more oil to protect the powerhead.
What spark plugs are you using?
Chris1956
Re: smoking
DHadley, Are there suitable water seperators for that motor available as aftermarket? Sierra?
peteg
Re: smoking
Dhadley
I am running the reconmended spark plug champion Ql78yc, They are gap at
.035, I put the Racor 10 micron filter on because of the enthanol gas, they say with out it you are looking at a bill to clean the water out of the carbs,
Also someone said that my vro pump is bad or going bad that the membrain gets a hole in it and pumps extra oil is this true .... ? Is there a easy way to check this out ... ?
Thank you very much for your help
peteg
Re: smoking
Willy, Is there anything else i can check with out taking the filter out,
any help would be appreciated ........ Pete
