Hi
I got problem with a -89 40 HP Evinrude (TE40ELCEC) wich came with the boat i buyed this winter.
With no gear in the response is good (disconnected the gear shift wire to test) it sond and feel very responsive. As soon as i put a gear in and give thrust the engine never revs above 1500 (on tach instrument).
I did disable the VRO system by plugging the oil hose to the pump (Did not diconnect the three wire connector as i read about it just now and dident know when i was at sea) and disconnected the tvo wires from VRO tank.
I did 5-6 short (900 meters) test runs, at two of them the temp warning started to sound.
The water coming from the engine seems very cool, maby to cool so i think that maby the thermostat is broken but that still wouldent explain the problem. I even ran it in an oil drum for abot 10-15 minutes without feeling the exhaust cooling water getting any warmer.
Another thing is that it's fitted with Champion L78YC sparkplugs. I see in OMC part database that it suppose to be QL78C. Checked it on Champin site it seems like the missing Q is the marker for "RESISTOR-CDI" and the extra Y is for "STANDARD PROJECTED CORE NOSE". Can this be a part of my problem ?
The revs is so steady at 1500 that i suspect it's somekind of regulator kicking in and i did read about the S.L.O.W feature. Is it possible that iv got that on this engine and if so what can i do to check it.
Any help would be super as i put a LOT of effort into this boat and now when the summer finaly is here the engine fail on me.
