Re: 140-4cyl omc
Keep looking.
The outdrive has the wrong gear ratio, and no amount of prop changes will get you the same effeciency, speed, etc that having the proper gear ratio will. If it did, the manufacturers wouldn't have different gear ratios, just a bigger selection of props.
OMC (Especially the striger drives like the one you mention) aren't built anymore, haven't been since the mid 80's. OMC itself went out of buisness about 10 years ago. But hey, with some careful searching you should be able to find parts, not sure about someone to rebuild the drive for you, but that is the problem with Edsels & DeSoto's, fun to look at, just not fun to buy parts for.
