I recently bought a old 1969 mercury 40 4hp outboard. Noticing that there was no water coming out of the pee hole, only hot air, I took apart the water pump and the impeller looked fine. Removing the clean water flushout bolt on the lower rear of the motor and running the motor in a tank, water will circulate out the flushout hole. Does anyone know if this motor has a thermostat? Or any ideas for getting the water to come out of the pee hole? I assume something is plugged up but not sure where to look or how to get it unplugged.
Thanks in advance
Thanks in advance
