  #1
Old May 30th, 2007, 01:12 AM
socalboataddict socalboataddict is offline
Default mercury ignition switch replacing
Hi
specs: 1993 90hp outboard Mercury with quicksilver control panel.
I intend to replace my factory ignition switch because it may be faulty.
I see one here for at IBOATS
http://www.iboats.com/3_Position_Pus...-view_id.49307
for under 20 bucks with the same type of function i.e 3 position with push to choke.
two questions: 1. compatibility? I read here that any after market switch should work.
2. degree of difficulty? I imagine that it is just remove and replace with correct coded wires.
Am I delusional that this would be an easy job to handle?
thanks
Socalboataddict
  #2
Old May 30th, 2007, 08:17 AM
jmburock jmburock is offline
Default Re: mercury ignition switch replacing
Simple but tedious job. That switch should be compatible but may not have all the same markings (A,B,C,S,M,M). I recently did mine, used a Sierra push to choke 6 pin switch from Boaters World that was 100% compatible and only $18.
Pull the controller off, separate the back plate, pull out the old ignition switch. Then re-connect each one, individually so you don't forget which went where. Some of the leads may be short if they are cut/ corroded- easy to add extra length if necessary. At most this is a one hour job.. After re-installing, check switch box for any voltage at the black/yellow terminal (should be 0 volts).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Mercury 40HP - Ignition Switch Box, Replacing wires... TheChad Mercury & Mariner Outboards 24 July 26th, 2007 01:27 AM
Mercury ignition switch Nighthawk Electrics, Electronics and Trolling Motors 2 March 26th, 2007 05:33 PM
replacing trim/tilt switch in mercury shifter bbcullen Mercury & Mariner Outboards 6 March 8th, 2007 04:38 PM
replacing ignition switch on 79 merc 80hp ayenlit Mercury & Mariner Outboards 3 August 2nd, 2005 08:00 AM
mercury 700 ignition switch ol merc Mercury & Mariner Outboards 0 September 14th, 2002 03:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
