  #1
Old May 29th, 2007, 08:39 PM
manny1 manny1 is offline
Unhappy OMC Cobra Engine Block
My OMC 5.7 V8 Engine blocks cooling system was not fully drained for winter storage and developed a hairline crack on the block below the manifold.
Can this crack be welded or patched and if so, does the engine have to be removed in order to weld it?
How difficult is it to remove the engine?
Is there a local repair shop in the Toronto area?
  #2
Old May 29th, 2007, 08:45 PM
Rob454 Rob454 is offline
Default Re: OMC Cobra Engine Block
You can probably weld it depending on where the weld is. if its on a cooling passage or elsewhere. Depending on how much room you have to get a welder in the area. the welder may need to grind the crack. I woudl pull the motor since you have one crack there may be others.
I have heard of people welding up a crack in a block but its not normally done
Rob
  #3
Old May 29th, 2007, 10:06 PM
gcboat gcboat is offline
There's a product called JB Weld. I've read some of the testimonials and this stuff seems to be pretty good at doing what you want to do. I've never used the gray ( block sealer ) before but have the white. Indeed good stuff. As Rob 454 says this is not a common practice but it just might get you through until that shiny, new engine arrives. Hey, nothing ventured, nothing gained. It's already broke, can't do much more damage to it. http://jbweld.net/products/jbweld.php. There's your link.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Marine engine block versus Auto engine block JKEP44 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 28 August 29th, 2007 11:50 PM
1992 omc cobra 3.0 cracked block, can i use a chevy 2.5 auto block??? sandman44andahalf Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 June 19th, 2006 05:20 AM
Which GM block is 1988 5.7 Cobra (Four Winns 200) Stan's Customs Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 November 30th, 2004 06:59 PM
Marine Engine Block vs Standard Block Rhathid Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 18 April 13th, 2004 05:56 AM
1989 OMC Cobra Block jee70611 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 October 31st, 2002 05:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
