I just got this motor from a friend and it hast been run in 6 years. I got it started fine it runs great at top speed. Water pump is working great.
Only problem is when I lower the throttle it dies. I tried adjusting the idle a bit and it helped some but I cant even slow down enough to change from forward to neutral then to reverse, it dies before I can get there. Makes for a really hard time in a crowded restaraunt slip.
Could this be a carb issue? fuel pump? what would be a good starting point?
