  #1
Old May 29th, 2007, 04:51 PM
jjiboats jjiboats is offline
Default shift linkage removal 85 hp Evinrude
I am tring to remove lower unit on a 1974 85 hp Evinrude. I have losened the bell crank halves and seperated the shift linkage from the bell crank. The manual says it should drop. It looks like its hanging on the shift rod conector.
Don't see a way to remove it from the shift shaft.
Any help would be greatly appreciated.
Joe
  #2
Old May 29th, 2007, 06:12 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: shift linkage removal 85 hp Evinrude
If you have both halves of the bellcrank shift connector off and away from the barrel shift connector that sits (threaded) on top of the shift rod, it isn't the shift connector that's hanging up.
More likely it's the driveshaft splines rusted within the crankshaft splines. This happens when someone has the lower unit off and neglects to install the upper driveshaft O Ring and thoroughly grease the driveshaft splines.
  #3
Old May 29th, 2007, 07:42 PM
Thanks for the help. It was the shift rod connector not lining up with housing. Moved it around and it dropped.
  #4
Old May 29th, 2007, 08:32 PM
Joe Reeves's Avatar
Amazing, you're lucky.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 50 hp Evinrude Shift Linkage removal njbob Johnson & Evinrude Outboards 4 May 15th, 2006 04:45 AM
Shift linkage removal 88 horsepower Evinrude B.autry4711A Johnson & Evinrude Outboards 1 March 22nd, 2005 03:03 PM
V4 OMC Shift linkage - Any removal tricks? JasonBenson Johnson & Evinrude Outboards 13 May 9th, 2004 03:13 AM
96' Evinrude 115 Shift Linkage Reassembly petiboy Johnson & Evinrude Outboards 9 August 10th, 2003 07:42 PM
1958 Evinrude shift linkage coupling Motown Johnson & Evinrude Outboards 3 May 9th, 2003 10:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
