Re: runaway 150 evinrude not good
first startup of season boot on good stream of water running about 1000 to 1500 rpm motor runs away to full thottle by itself .
What is the model number as there are a number of different designed 150's?
If it is a FICHT 150, then the fuel pump diaphragm may be leaking into the crankcase.
If it is a 60? engine, then the OIS sensor, electric eye, may have gone crazy.
Another possibility is corrosion on the throttle shafts and one sticking open a ways if you move the throttle lever.
First off, remove the air box and inspect each of the throttle plates to see that they close and open together and that the spark advance linkage is not sticking.
good luck
