  #1
Old May 29th, 2007, 11:33 AM
Hoss IV Hoss IV is offline
Default Knocking noise at idle Yamaha 175
Help!
I bought an Overnighter with a 1996 Yamaha 175. I had the boat professionally winterized and carbs redone. When the boat was splashed this year she knocks at idle (it didn't do this on sea trials prior to purchase). The knocking does not occur in neutral. Seems to go away at 900 rpm. The boat turns up fine with no slipping. Cruise at 3400 and can run WOT at 5400 with no problems. She still has a sticking float on the one carb.
Any ideas what this might be? I would hate to do any damage by running her.
Thanks!
CJ
  #2
Old May 29th, 2007, 04:43 PM
Default Re: Knocking noise at idle Yamaha 175
HEEELLLPP Anyone have any experience with this problem?
  #3
Old May 29th, 2007, 06:42 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
if somebody fixed the carbs and still is sticking take it back
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #4
Old May 30th, 2007, 08:58 AM
Thanks. I did take it back....the float sticking doesn't scare me as much as the noise in clutch gear. Why would it make the noise in gear and not idling in neutral?
  #5
Old May 30th, 2007, 09:08 AM
Ray Neudecker Ray Neudecker is offline
It could be because of the prop or incorrect thrust washer. Failure to replace the bowl gaskets or needles is the primary reason for intermittent needle sticking
  #6
Old May 30th, 2007, 09:19 AM
thanks for the comeback. What is the thrust washer? It didn't make this noise during the sea trial, only after the shop did the water pump. There are some slight occlusions to the stainless wheel...I mean minor.
  #7
Old June 1st, 2007, 09:25 AM
gcboat gcboat is offline
Your thrust washer goes on your prop drive shaft. It's a big round piece of metal that keeps the prop from wandering fore and aft on the shaft. Call it a spacer if you will. Check your connecting bolts on the lower unit, check and match your serial number on the unit as well.
  #8
Old June 1st, 2007, 06:34 PM
Osprey Osprey is offline
Hoss IV,
I have a 95 175 on a Grady 208. Shortly after I bought it, the motor developed a knock much like you describe. Thought it was a main bearing for sure but it proved to be a brass bushing that the upper end of the main shaft rides in.
With the lower unit removed, if you look up into the mid section, the bushing is the first opening that the main shaft would enter as the lower unit is being installed. The bushing is rubber coated and is retained by a large C-Clip. It can be removed without the need of a puller or any special tools. I now always grease the main shaft on the bushings mating surface prior to installing the lower unit.
A second possible cause? Being you just had your impeller serviced, I thought of this. Believe that starting in 95, Yamaha added what they call preload washers to the impeller assembly. This was to correct an issue with chatter and knocking sounds caused by the impeller. When your impeller was replaced these washers may not have been properly reinstalled. Maybe Ray could help with this as I'm not sure what sound this would make or when. Seems like it might only knock when the motor is first put in gear.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Knocking Noise 89webb Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 May 16th, 2007 11:09 PM
overheat-knocking noise Phantom17 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 September 4th, 2005 04:45 AM
175 Johnson Knocking noise,,need HELP.. HS20 Johnson & Evinrude Outboards 5 June 7th, 2005 05:53 PM
knocking noise when trimming down from WOT Bill P. Yamaha & Suzuki Outboards 2 March 21st, 2005 02:15 AM
3.0 Cobra knocking noise VMAX Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 October 1st, 2002 05:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
