  #1
Old May 29th, 2007, 11:20 AM
jglad's Avatar
jglad jglad is offline
Default More Starter troubles 68 evinrude 55hp
I got my Prestolite MGD4006 starter rebuilt and it cranks good again, but now the driver gear is shot and I have to manually push it up in to the flywheel to get it to crank! It is a real pain to take the cover off and push the gear up everytime I want to start it, is there any fix for those gears or does anyone know where I could find a replacement one?
It is the 12 tooth style.
Thanks for the help!
__________________
1968 Evinrude Triumph 55HP
1969 Duratech Neptune 16' Runabout
1993 Regal Valanti 176SE 4.3L Merc
  #2
Old May 29th, 2007, 11:42 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: More Starter troubles 68 evinrude 55hp
have you tried putting a couple of drops of 3 n 1 oil on it.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old May 29th, 2007, 11:59 AM
jglad's Avatar
No, it was suggested to me to spray a bit of carb cleaner where the gear meets the clutch on the drive gear, where would you suggest I put the 3 in 1 oil?
__________________
  #4
Old May 29th, 2007, 12:03 PM
on the shaft, where the gear spins up. not enough for it to drip into the motor. the part # is 383195. tried several places, listed as NLA, you can try, tcoutboard.com or seawaymarine.com seaway has a lot of nla parts, they stocked up on. call tcoutboard they can't answer all the emails apparently.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old May 29th, 2007, 12:23 PM
you've probably already heard this. are you sure the battery is good. have you had it load tested. take jumper cable from pos battery to pos on the starter, see if it will engage. this part is canned,copy and pasted from another post. remove the cable from battery and motor, also from solenoid to starter. clean till shiney. also check for any nicks of swelling, as they tend to get nicked and deteriorate from the inside out. the replace, and tighten well. 90% of starter problems are battery cables. you can put a couple of drops of a light oil on the starter shaft, like 3 N 1 oil. don't drown it. you don't want it to run down into the started. wd 40 is a no no.
__________________
FLORIDA GATORS
TEBOW Country
  #6
Old May 29th, 2007, 04:18 PM
cancan cancan is offline
I have the same engine and finally gave up the starter. I went and found a fly wheel from a 69 triumph 55hp and bought a new 9 tooth starter and have lost the problem once and for all.
  #7
Old May 29th, 2007, 05:21 PM
jglad's Avatar
So, I called and spoke to Pat at TC outboard, he said that he did not have any starter parts for this model, but that he didn't think that the drive gear was bad. He said that it was an inertial starter system and that either the starter is not spinning fast enough to send the gear all the way up, or that the shaft needs to be cleaned and lubed (I think I see a trend developing here...). He also mentioned that since I just got the starter rebuilt it may need to be run for awhile to loosen up, like I should let it crank for 15-seconds.
So, I guess that is what I will do, get the shaft cleaned and lubed and check all of my cable connections and see where that gets me.
Thanks for the input Cancan, I asked that same question here last week and was told that it was not going to be cost effective to swap it all out. Maybe if I can't get it working properly, I will look into that again.
__________________
  #8
Old May 29th, 2007, 07:58 PM
when it works can i say 'told you so'?
__________________
FLORIDA GATORS
TEBOW Country
  #9
Old May 29th, 2007, 08:05 PM
jglad's Avatar
If it works you are more than welcome to say "I told you so" all you want.
I hope you are right and I will find out tomorrow night when I work on it!
__________________
  #10
Old May 30th, 2007, 08:02 PM
jglad's Avatar
Thumbs up Re: More Starter troubles 68 evinrude 55hp
Quote:
Lay it on me, man:
"you told me so, you told me so, you told me so, you told me so!"
I figured that the connections and battery were good, so I wiped the shaft down with a clean rag and the just put some Rem oil on there (above and below the gear) and worked it up and down for a few minutes.
Viola! it cranks!
thanks again for the help
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1968 Evinrude 55hp starter problem jglad Johnson & Evinrude Outboards 4 June 27th, 2007 12:55 AM
'76 evinrude 55hp temp switch troubles wtarcher77 Johnson & Evinrude Outboards 5 September 21st, 2006 10:53 PM
Starter Troubles riden Johnson & Evinrude Outboards 3 August 14th, 2006 03:37 PM
1969 Evinrude Triumph 55hp selectric shift starting troubles klwright48750 Johnson & Evinrude Outboards 9 August 10th, 2006 10:16 PM
Starter Troubles RonaldB Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 August 8th, 2006 02:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
