Can I use essentially any marine tachometer with this motor?
It has the three wires leading out of the control box, and in checking Teleflex's web site I gather that it probably has the 6 pole alternator, therefore the 3 cylinder setting would probably be appropriate.
Is this correct? I just mounted it on a pontoon boat that already has a tach in the dash, but I wanted to verify that it will work before I connect it.
Thanks in advance!
Thanks in advance!
