Right on to the point. Does anyone know what the switch or lever underneath the engine (outside the casing) is for that gets tripped when the engine sits close to the hull or in all the way down position. This is a manual tilt engine. I am having trouble putting my 89 Maxum into 3/4 throttle position(pull hand towards you and push forward to prime or throttle) due to a stopper mechanism directly at the bottom of the engine. The cables work great, it shifts into forward and reverse but won't do the prime deal because when I start the throttle forward the two pins or cams line up directly and stop the throttle from opening. In forward the cam is offset to the bottom. In reverse it is offset to the top. Does the engine have to be all the way down to trip that lever and thus free up the throttle? WHERE CAN I FIND An 89 MAXUM MANUAL. Seloc Online has taught me zero!!
