Hey!!! I just bought a 1971 Venture 17. I have cleaned it up and taken it out sailing twice. The first time, I had a little water in the bottom of the boat. It collected around the area in front of where my Keel bolts are. The second time I took it out. I got down in and looked to see where it was coming from. I thought was coming in during launch or during sailing, But it turns out it isn't coming in at all. I was very happy to find this out.
THe water was very stagnent and, apparently gathers around the inside of the boat when it is trailored. It settles back under the cockpit and collects. There really isn't enought worry about. I just sopped it up with a towel. Now for real problem. Back under the cockpit inside the boat. it is covered with green gunk. algae and General Lake Slime I assume, that has grown there from it setting on the trailor tilted back. I can't get to it because the area is too small for me to get back into. I can reach it with a mop and cleaner, but that constitutes adding water and cleaner to the mix and more sopping up with a towel. I don't mind doing this, but I was wondering if anybody has ever put a boat plug in the transom or back in that area to drain such problems? The only reason I hesitate to do this is because I hate outting holes in boats. It could let water in and we definitely don't want that. Any advice would be appreciated.
