Hey guys - I'm hoping that someone can point me in the right direction . . . I have a clymer manual and it's no help. Service manual is in the mail.
I recently bought a 1989 Mercury 50hp that's in beautiful shape. The trigger and stator were bad . . . after I replaced them the motor has spark in all 3 cylinders (when I ground the plugs to the block).
Tested compression = 120psi in all 3 cylinders
replaced fuel pump, filter, cleaned carbs . . . fuel system is supplying fuel to all 3 cylinders.
When I put the plugs (New plugs = NGK BU8H) back into the motor . . . I swear there's no spark.
The motor doesn't fire at all. Doesn't kick over . . . no smoke . . . nothing.
even with a fully charged battery and fresh fuel. I even dipped the plugs in fuel and put them back in the motor.
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Thanks for the link to MaxRules . . . It got me focused on weak/no spark and getting more juice to the starter so the flywheel could move faster.
I replaced the starter solenoid and the battery harness. I put some fuel in one hole and pulled the other two plugs (hoping that the motor would spin fast enough to create spark) The motor started right up on one cylinder. Repeated on 2 and 3. Then I put all the plugs back in and the motor fired right up. Problem solved . . . . idles perfectly and starts immediately.
