Re: 1980 Mariner 30HP possible exhaust problem
first with no telltale, you have no cooling, the tt is the last thing in line, the block fills and then the pressure of the impeller pumps water out the tt. if it is pumping the water is not getting there, an exhaust leak in to the cooling system, stops the flow of water. or a pressure leak in the head does the same thing. they push the water back down the tube. good call. check it out.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
