  #1
Old May 26th, 2007, 01:55 AM
burnsy111 burnsy111 is offline
Question lower unit drain hole blocked Evinrude 15 hp
I bought a used 15 hp 1985 from someone who I thought was trustworthy.
He said engine iwas serviced and ready to run, I did start and test in tank in neutral only. I checked lower unit oil to be on safe side and realized it was not at top of vent plug. I removed drain plug and discovered that the hole was basically welded closed or filled with an epoxy. My guess is that previous owner stripped threads and did this as a cheap fix. 2 Questions
Can I fill unit with oil through vent plug?
Did running it for 5 minutes in tank in neutral cause damage to water pump or lower unit since it had no oil.?
I took it to a local mechanic and he said my only option would be to replace lower unit since filling from vent hole would not allow air to escape.
Appreciate any advice
Thanks
  #2
Old May 26th, 2007, 02:32 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: lower unit drain hole blocked Evinrude 15 hp
I'm not particularly concerned about the water pump. It's separate from the gearlube altogether. This'll be terribly inconvenient but it will work...you can remove the gearcase and remove the driveshaft to both drain and fill the gearlube. Remove the upper vent screw as well. Invert the gearcase to drain it and then put it back upright and fill through the driveshaft hole til it comes out the vent. You'll need a foot of small hose attached to the gearlube bottle to guarantee that you get the gearlube down inside the bullet. Put the hose down into the driveshaft hole til you know you're well down inside and force the gearlube through it til it comes out the vent. Put the driveshaft back in, put the vent plug back in, and reinstall the gearcase. Service the water pump at the same time. If you're in there for the water pump anyhow, it's not such a big deal. But it sure is a lot to just change the gearlube.
To facilitate a quicker drain, it might be necessary to crack the shift pivot screw. It's a phillips-head screw down by the drain. Do NOT remove it, just back it off it's threads and leave it in there. It'll allow air in as the gearlube drops out. Otherise it might take hours to fully drain all the gearlube out. Don't forget to tighten it back up after it's drained.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old May 26th, 2007, 06:05 AM
F_R F_R is online now
Heck, just put a Heli-Coil (thread repair) in the screw hole. For just one repair, it would make sense to take it to an automotive machine shop and have them do it instead of shelling out the $ to buy a whole kit.
As for the 5 minutes, how long did the previous owner run it that way?
  #4
Old May 26th, 2007, 09:55 AM
Thanks for the advice, I agree that would work but I want to avoid dropping lower unit if possible. I did crack the pivot screw and blew compressed air into the vent hole at the sam time. Air came out of the pivot screw hole with no sign of any gear lube. I think the lower unit is bone dry. Therefore I only need to add, not drain. Can I do your suggestion and just insert the tube through the vent hole as far as I Can and wait until I see lube come out the pivot screw hole, then tighten that and keep adding until it comes out the vent hole. About how much gear lube should the lower unit take?
I figure it might be worth a try as I will have to replace the lower unit and water pump anyway if prior owner ran it without lube in there.
  #5
Old May 26th, 2007, 10:59 AM
You can use a pump type oiler can and just put it in the top plug very slowly. It will run downhill by gravity and fill from the bottom. Don' know the capacity offhand, but would guess it to be on the order of 10 oz.
I still say go get a heli coil put in it though. No need to drop the lower unit.
  #6
Old May 26th, 2007, 02:26 PM
Can I just add lube through the vent hole without dropping lower unit since I dont have to drain because there appears to be no lube in there?
  #7
Old May 26th, 2007, 02:36 PM
No. You'll always have a bubble of air below. I suppose it's possible, but it could take hours or even maybe days.
__________________
  #8
Old May 26th, 2007, 03:11 PM
Yep, a few drops at a time. That's why they put two plugs in it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
EVINRUDE 92 50 LOWER UNIT OIL DRAIN AND REFILL QUERY rajabatis Johnson & Evinrude Outboards 14 September 19th, 2009 04:29 PM
lower unit drain hole cbsykes Yamaha & Suzuki Outboards 6 April 5th, 2005 08:02 PM
88' 70HP Evinrude Lower unit drain/check plugs scott324 Johnson & Evinrude Outboards 1 October 29th, 2004 03:02 PM
1967 Evinrude 18hp hole in lower unit? mulv80 Johnson & Evinrude Outboards 2 April 30th, 2004 06:04 AM
transom drain blocked with engine mount bmurray Mercury & Mariner Outboards 2 May 24th, 2002 08:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
