1993 135hp Mariner that can not go above 3500 rpms
I have a 1993 Mariner 135hp 2 Stroke motor. Recently, the motor began to run rough. The number one and three cylinder had fowled plugs. My first thought was the fuel. I installed a water fuel seperator, fuel filter and rebuilt the carbs. The boat ran fine for about an hour and then I could not seem to get the engine to go above 3500/4000 rpms. It ran like it was missing. If I changed the plugs, it would run fine until they fowled. I tested the the switch box and coils. They tested fine. I still changed them anyway. Coils where next. After pulliing the flywheel I found that one of the magnets had come undone. I changed the flywheel and stator while I had it off. Still the same thing. It seems to run at idle fine, but can not get over 3500/4000 rpms and running rough at 3/4 to full throttle. Does anyone have any ideas?
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Re: 1993 135hp Mariner that can not go above 3500 rpms
Fouling plugs sounds like either too rich a mixture on those cylinders or an erratic spark. Check all the wires from the switchboxes to the coils and the wires on the coils to ground.
Check all your fuel lines as well for cracks or loose connections.
__________________ Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
I had a bottom seal problem with the same motor. Caused all sorts of erratic behaviour, poor idling and short lifed plugs. Bad starting occassionally and lack of power. Hard thing was getting the powerhead off to fix it as the front long studs were frozen into the exhaust plate. At the age your motor is it may be something worth considering.
