Hi I'm not too knowledgable on outboards so here goes. First is there supposed to be a little play in the prop? I can move it about an inch back and forth. Second, what is the best gear oil to use and how often should you change it. And finally does anyone know if there is some kind of alternator you can install on this motor? Charging the batteries before everytime i go fishing is getting annoying. The motor is a 2002 mercury 90hp 3 cylinder, oil injected. Thanks for any help.
