  #1
Old May 25th, 2007, 12:07 PM
hawks13 hawks13 is offline
Default Problme Starting 2001 200HP EFI Mercury Outboard
I have a 2001 Mercury efi 200hp Mercury Outboard motor that I am having trouble with starting. When I try to start the motor, it sounds like its not getting gas or something. When I take the cover off and should some starter fluid in the choke, it starts right up like nothing and runs perfect. The if I turn it off and wait about half an hour, it will start up again. The problem is if I wait longer, it won’t start until I spray starter fluid in the card again. Does anyone know what this might be.
  #2
Old May 25th, 2007, 02:22 PM
gss036 gss036 is offline
Default Re: Problme Starting 2001 200HP EFI Mercury Outboard
Hawks, welcome to the board.
You should not be using starting fluid on your 2 stroke motor, especially on a regular basis as it will was off the lube and has the potental to cause you problems. Try using the spray SeaFoam as it has some lube in it.
I am not familiar w/EFI systems, but I would suspect that your choke/enrichment valve is not working (if you have one), other wise you are loosing fuel pressure w/the EFI system and it is not priming the fuel system.
Hopefully the experts will jump in and give some ideas.
  #3
Old August 6th, 2008, 07:00 PM
bayfun bayfun is offline
Suspect you have bad gas- water. Remove your filter and drain, if you have an additional filter out of the engine compartment drain or replace. Be sure to use a 10 micron filter in the one outside your engine cover. West marine has them but some are 21 micron. A new Merc filter to replace the one in the engine cover is only $25.oo from a merc dealer with a new water sensor. Now the secret may be that you have water in a chamber where the oil is mixed with the gas. This will stop your engine from starting. Looking from the front of your engine you will see a silver box with what looks like part of a cylinder in front of it with a dome on the top. There is a drain plug at the bottom of this cylinder. Open it with a can and rags beneath it. Drain it. Then put the plug back in. Use your fuel bulb to pump NEW fuel in it and try to start. There is also a needle valve in this compartment that can be damaged if sitting in water to long. Water in gas is a problem with the new etenol gas. Let me know if that works.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 125 HP Mercury Outboard mary ann Mercury & Mariner Outboards 4 May 28th, 2008 08:51 AM
1991 Mercury 200Hp Offshore-Starting Difficulty Randy W. Mercury & Mariner Outboards 6 December 17th, 2006 08:29 AM
1989 Mercury Blackmax 200hp outboard Dualie Mercury & Mariner Outboards 1 May 29th, 2005 07:34 PM
2001 Mercury 25 HP Starting Problem MD1 Mercury & Mariner Outboards 5 May 12th, 2005 05:56 AM
2001 Mercury 25HP Outboard Problem - HELP BigKeyserSoze Mercury & Mariner Outboards 4 October 1st, 2004 02:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
