  #1
Old May 25th, 2007, 09:51 AM
fishon71 fishon71 is offline
Default 1988 Yamaha not getting fuel - dies
Fishing trip canceled on such a nice day!
I have a 1988 Yamaha 130 carburetored motor. Put her in today for my first run of the season. Motor dies not getting any fuel. Seems when you pump the primer ball it does not get hard and hold the fuel thought the system. If I pump ball 20 times it starts them dies.
Fuel pump replaced 50 hours ago
New 10 micron water/fuel separator
Cleaned all filters
50 gallons of fresh fuel
What keeps the fuel from feeding back to the tank? Is there a check valve of some sort in the ball or fuel pump?
Thanks
  #2
Old May 25th, 2007, 10:44 AM
Default Re: 1988 Yamaha not getting fuel - dies
Update: Pulled filters and water seperator, clean again (not dirty) no water founf in seperator gas looks clean.
Hooked up different tank and hose to engine, got running but runs like crap. Last season I made the mistake of running tank dry - sucked in a ton of crap and carbs got clogged. I pulled down carbs and cleaned and it seemed to run okay in the yard afterwards - make me think fuel pump got all screwed up with dirt. I did not take it apart.
What do you think, pop in a fuel pump? Its only $$$
  #3
Old May 25th, 2007, 06:53 PM
Ray Neudecker Ray Neudecker is offline
No doubt it needs replacing. You might also check the antisiphon valve in the tank pickup.
  #4
Old May 25th, 2007, 08:11 PM
Okay replaced fuel pump no improvement. Pull carbs, tore down, soaked and blew out. Put back together and seems to run fine in yard on auxilary fuel tank and different hose.
I'm still concerned about the anti siphon valve you mention, were can this be found as I try to prime from the main tank (50 gallon in hull) and I can't get a prime.
  #5
Old May 26th, 2007, 10:06 AM
It is a small ball in the pickup barb where you hook the hose to the tank.
  #6
Old May 26th, 2007, 10:35 AM
I don't see that on my set up.
Mine goes tank - shut off on outout of tank - hose - water/fuel sep - hose - primer ball - hose - glass filter - hose - Yamaha filter - hose - fuel pump - hose - carbs
There is a check valve ball in the primer bulb, I think mine is bad as I tried another and it works fine - on my way to the store for a new one.
  #7
Old May 28th, 2007, 09:52 AM
Fixed - replaced primer ball as check valve was bad in old ball
  #8
Old May 29th, 2007, 07:01 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
good to hear it ws that simple
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 Evinrude 15 HP starts ok then dies in a few minutes fishon71 Johnson & Evinrude Outboards 2 November 25th, 2006 04:54 PM
1988 60hp Mercury dies after getting warm partybarge60 Mercury & Mariner Outboards 5 September 21st, 2005 09:25 AM
1988 Yamaha 130 will not run at WOT and dies ??? fishon71 Yamaha & Suzuki Outboards 14 June 14th, 2005 04:54 AM
Fuel Pumps on 1988 yamaha 200 sounds like lawn sprinker bigshrimpin Yamaha & Suzuki Outboards 0 July 1st, 2003 07:04 PM
1988 Jonson 140 runs great, then dies..sometimes.. Majik Johnson & Evinrude Outboards 2 September 23rd, 2002 06:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
