mercury mariner 150 engine trouble?
bbull70
I have a 1989 mercury mariner 150 outboard (V6 w/ carb) on a 18ft boat. Freshwater only. I have only had the boat and motor for about six months.
I had a cylinder firing issue and a mercury dealer replaced the engine switch box (part# 32-778A12). The boat ran ok the next time out after that, but I am still having problems with idling. I can never seem to get the idle set right. Inconsistent acceleration and power, I removed the spark plugs yesterday. The plugs were new, I put them in shortly after I got the motor and they only had about 5 - 7 hours of total run time on them. Five of the six plugs had oil on them and they all looked pretty black.
The weird thing about this motor is one time out it will run and sound great 42-44 mph @ 5700 rpm, the next time out I hit the accelerator and the motor boggs down and dies.
Any advice, help, thoughts would be greatly appreciated!!!
studlymandingo
Re: mercury mariner 150 engine trouble?
The plug without the oil on it is what you need to focus some attention on. Is it completely clean? If so, you could have some water getting into that cylinder.
The motor could be running rich as well, loading the motor up which would explain excess deposits on the plugs. A thorough carb cleaning would be a good idea.
You could still have a firing issue as well. You should check all of the ground wires on your coils, if you have a lot of corrosion, or deteriorated wires, that can cause intermittent spark issues. You also should check the wires running from the switchboxes to the coils for the same type of problems. I have the same motor as yours, mine is run in saltwater. I have had to systematically replace all of the aforementioned wiring.​
bbull70
Thank you very much,
Yes, the one plug was dry and very clean, maybe just a little black on the outside. The other plugs having oil on them (wet) that is normal or ok ?
Thanks for the other tips on wiring and the coils, sounds like that may be my trouble.
curtis63
bbull70, I think I'm having the same problem with my motor as you are. Mine will run fine, the after turning it off and starting it back up a few minutes later, it will not let me rev it over 1400rpm with the gears engaged. Then, I'll turn it off and restart it and after a few tries, it will start working perfectly again. It won't stutter or stall at all once it's working, but after shutting it down and restarting, it might stop working again..
Did you ever get a solution to your problem? What ended up being the problem?
Thanks,
Curtis
