  #1
Old May 25th, 2007, 01:48 AM
ck85abc3 ck85abc3 is offline
Default I checked out a used boat today: 3.0 OMC Question
I looked at a 87 bayliner 18 foot today and have a question.
They started the motor with muffs on and put it in forward and reverse, but had to work it into gear. WHile working it into gear there was some light grinding. Is this a sign the outdrive is going to go out or can it be fixed with adjustments?
Thanks
  #2
Old May 25th, 2007, 02:06 AM
superpop's Avatar
superpop superpop is offline
Default Re: I checked out a used boat today: 3.0 OMC Question
depends on the drive, I have a volvo drive and if you casually and slowly try to put it into gear it will grind. If you shift with authority and do it quick it should simply thud a little bit but not make much noise. It also sounds different out of the water vs in the water. out of the water mine just sounds like a blender starting up but I do get a bit of the thud when I am in the water. Also I have heard that the OMC drives were hard to get parts for and find service techs that would work on them. I would really research this drive before buying something you are going to regret.
  #3
Old May 25th, 2007, 02:52 AM
Scaaty's Avatar
Scaaty Scaaty is offline
An OMC O/D on a Bayliner? Run, Forrest, RUN
  #4
Old May 25th, 2007, 03:55 AM
Quote:
That's what I thought. I figured a 3.0 bayliner would have a mercruiser.
  #5
Old May 25th, 2007, 07:33 AM
RubberFrog's Avatar
RubberFrog RubberFrog is offline
It sounds like the shift cable is out of adjustment. Those can be tricky to get adjusted right and not many mechanics know how to work on OMC anymore.
I had a 3.0 OMC and it was a HUGE moneypit. I would not even consider owning another if it was free.
  #6
Old May 25th, 2007, 10:46 AM
andy1canada's Avatar
andy1canada andy1canada is offline
Howdy CK!
I'm with Scat on this one.
Before you've dropped a nickle on this boat, you've already got 'two-strikes' against you:
1) Bayliner!
2) OMC!
3) Your outta' there Buddy! Disgusted... dicharged yourself from the power-boat fraternity after buying that damned 'Bilgeliner'... that proverbial 'hole-in-the-water'...
'God... what was I thinkin'?'
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Took the boat out today SoulWinner Dockside Chat 17 December 18th, 2006 07:53 PM
Glad I checked for leaks imported_John_S Boat Restoration and Building 0 May 2nd, 2005 04:13 AM
Trim up not down, checked everything possible please help! Tempest16 Johnson & Evinrude Outboards 6 May 8th, 2004 11:38 PM
How can a 1972 6hp Johnson be checked for RPM Bob H Johnson & Evinrude Outboards 4 June 21st, 2002 05:40 PM
I just checked my compression ,What do you think?? PULLNIT Johnson & Evinrude Outboards 6 February 27th, 2002 03:03 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
