Manipulator
- Apr 11, 2005
- 743
The weather is nice and it is time to repair my stingers. What has happened is my rams were leaking hydraulic fluid; the fluid ran down into the motor mounts and penetrated the fiberglass that the stingers are encased in. These caps popped right off (see pic). They had a piece of wood attached to the side of the stringer for one lag bolt, the other two were in the stringer. this was then glassed to the stringer. I have since cleaned up the area with acetone and now is the time for more prep. I plan on more cleaning with acetone and then roughing up the area with a Dremel tool. The stingers seem ok but a few lags just spun, few were rusted (threads about gone). I plan on filling the holes with epoxy, then hammer oak dowels in and redrilling. I bought galvanized lags. Here are my main questions?
1.) What would you suggest with regard to epoxy? Can I use poly or is that a bad idea?
2.) What type of mat or cloth should be used for the best strength? We are talking stringers so I imagine using the right fiberglass is key. Do I use
cloth or mat? Woven, biaxial or what? Sorry I am this is all new to me.
3.) How much build up, how many layers?
4.) Prep between layers
Thanks for your help.
