1999 Evinrude 115 FICHT Boggin down
Ok, ive got a 99 115 FICHT that im about to pull my hair out over! everything was fine last summer/fall when she was put up. it ran fine and the gas was treated with Stabil. since then until a few weeks ago i would go out every now and then to crank her to make sure it was running ok . on our first run of the season it would not get over 1800 RPMs or so. sounds like its starvin for gas and missing kinda. at the time we thought we might need to pump the bulb but it didnt help. actually the bulb didnt seem right so i replaced that as soon as we got back in. went for another run and it had the same problem.
heres what has been checked or repalced;
primer bulb, inline fuel filter between tank and bulb and the fuel filter on the motor, pulled off the high pressure pump and cleaned the screen on the bottom, checked valve in tank and made sure we're getting gas from tank ok, replaced plugs, checked for each plug firing ok.
any help or ideas would be greatly appreicated. im willing to give the first person to help me fix this a steak dinner on me, lol.
is it possible to clean injectors or is this something a real tech should do?? thanks in advance....Buzzard
