I have searched much and cannot find this problem.
I have a 1990 Bayliner 2650 Sunbridge with a 5.7L Merc I/O with 2 barrel carb with electric choke, (looks to be a rodchester carb).
The engine will start but then the choke continues to open all the way up and kill the engine. I can start it and jump to the carb and manually hold it back and keep the engine running fine but if I release, it opens all the way up and kills the engine even when it is fully warmed up.
Is there a sensor somewhere that controls the choke or is the electric coil just gone bad (because it does heat up and open the choke)? I have loosed the three screws and in a warm state, have to twist it almost 360 degrees to keep it running but if I leave it there the engine will never start cold.
Any help is very much appreciated.
Thanks and Sincerely,
Allen
Allen
