  #1
Old May 22nd, 2007, 11:14 AM
jrmcgee1972 jrmcgee1972 is offline
Default loose starter 1982 Evinrude long shaft
1st issue, im not mechanically inclined whatsoever.
The engine starts and runs great. However, in order to start the engine I have to remove the cover and physically push the starter against the flywheel. If not the teeth dont engage enough to turn flywheel. when i push the starter against the flywheel- no problem- starts right up.
I noticed two empty screw holes, one on top of the starter casing and the second on the right side (As you're looking toward the bow) of the engine. They are the same size and it almost looks like there is a missing "bridge" that would serve to hold the starter tight to the flywheel. Looks like all i need is that bridge and two bolts. If anyone is able interpret my garbled description of this issue and can tell me the name of the part Id be grateful.
The parts department at my local shop suggested I need a new "Starter bracket". I dont think that is what I need based on my online research.
Thanks- JRM
  #2
Old May 22nd, 2007, 12:14 PM
Lubosleftboot's Avatar
Lubosleftboot Lubosleftboot is offline
Default Re: loose starter 1982 Evinrude long shaft
Thanks- JRM
What size is your motor i.e horsepower
You will find parts for OMC motors here http://epc.brp.com/login.aspx?Return...kieS upport=1
LLB
__________________
Kermit Klein fashion guru to the stars...
  #3
Old May 22nd, 2007, 12:27 PM
sorry... 35hp. I just got off phone with another parts guy and am more confused than I was before... thanks...
  #4
Old May 22nd, 2007, 12:33 PM
jtexas's Avatar
jtexas jtexas is offline
The part of the starter that engages the flywheel (bendix gear) needs a couple drops of light oil on the threads (I use 3 in 1 oil). Inertia throws the bendix against the flywheel (like jerking a tablecloth out from under the fine china), and pressure holds it there until the engine starts spinning faster than the starter motor, at which time the threads on the shaft bring it back down.
don't use wd40, don't use grease, don't lubricate the motor shaft, just the threads under the bendix.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
  #5
Old May 22nd, 2007, 12:46 PM
so 3&1 oil and some gauze pads is what you are telling me... sounds like fletch the movie. seriously, when you say threads on the bendix, are you suggesting the "teeth" of the "starter gears" ? apologies again for the lack of mechanical jargon and abilites.... and thanks for your input.
-JRM
  #6
Old May 22nd, 2007, 01:02 PM
CATransplant's Avatar
CATransplant CATransplant is offline
I'm not sure I completely understand. Are you pushing the entire starter? Does it move? It shouldn't move, as far as I'm aware. The only thing that should move when the starter engages is the little gear that jumps up and engages the flywheel gear.
If the whole starter's moving, then something's missing. You can use the parts diagrams to see which part it is.
  #7
Old May 22nd, 2007, 01:15 PM
jtexas's Avatar
its ok........the bendix is threaded on the inside.....and the part of the shaft where the bendix rides is also threaded.
the part indicated by the red arrow:
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 70Hp Evinrude Lower Unit Long Shaft or Short Shaft HBF4 Johnson & Evinrude Outboards 3 April 23rd, 2006 07:10 AM
converting evinrude 1984 9.9 long shaft to short shaft alan5505 Johnson & Evinrude Outboards 8 February 28th, 2006 04:58 AM
1971 Evinrude long shaft to short shaft alderman Johnson & Evinrude Outboards 3 September 14th, 2004 03:22 AM
25 HP Evinrude long shaft conversion to short shaft P. S. Johnson & Evinrude Outboards 1 June 3rd, 2003 10:15 AM
Evinrude Short Shaft to Long Shaft Question. thebigbuck Johnson & Evinrude Outboards 8 March 12th, 2003 11:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
