  #1
Old May 21st, 2007, 09:10 PM
loaderman loaderman is offline
Post 60s Evinrude forward problems..Help....
I recently purchased a 60s model evinrude 80hp. The motor starts right up with no problems and runs very smoothly when testing. I took it out to the lake for it's first test drive and it will go into gear, but when put in forward it seems to crawl. It will not plane out and goes very SLOW. When put in reverse it runs great and when in neutral it revs great. Anyone have any idea what could be causing this problem?
  #2
Old May 21st, 2007, 09:14 PM
F_R F_R is offline
Default Re: 60s Evinrude forward problems..Help....
When it is in crawl mode, is the engine racing at high rpms? Or is that at crawl speed also? Makes a huge difference in diagnosis.
  #3
Old May 21st, 2007, 09:18 PM
When the boat is in the water it gets it's full rpm range in neutral and reverse. When you put it in forward it does not get it's full rpms. It barely goes over idle speed. Could it potentially be something binding in the foot?
  #4
Old May 22nd, 2007, 09:27 AM
Chris1956 Chris1956 is offline
Wink Re: 60s Evinrude forward problems..Help....
Loader, First thing is to check to see if the throttle is opening all the way, when the motor is in forward. Some Evinrudes had devices whaic did not allow you to shift out of neutral, if the throttle was set too high. This may be out of adjustment or broken.
  #5
Old May 22nd, 2007, 07:08 PM
Lightbulb Re: 60s Evinrude forward problems..Help....
I have checked the throttle, and all linkages are working as they should be. Carberator is opening up full range in both gears and neutral. I spoke to a marine shop today and they told me to try cleaning the carberators. So, that's what my evening has in store for me. I will let you all know the outsome of that. If anyone has any more suggestions, I am definately open to them! Thank you so much for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Force 85hp 1987 idle/forward/reverse problems strippier Force & Chrysler Outboards 6 August 30th, 2004 09:28 AM
forward/reverse gear problems fish4food Force & Chrysler Outboards 1 July 1st, 2004 07:32 PM
77 evinrude will not shift into forward jery Johnson & Evinrude Outboards 1 September 7th, 2003 05:57 PM
FORWARD / REVERSE PROBLEMS wolfgramati2kcom Johnson & Evinrude Outboards 2 August 12th, 2003 08:54 AM
Update on my forward,forward and forward gears on '75 85hp Merc dkhntr Mercury & Mariner Outboards 0 June 5th, 2002 07:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
