Re: 1986 150 merc oil injection?
yes i agree here is the problem, I am looking at this boat to buy I do not want to purchase this kit to remove it for good unless i buy the boat and try to run it with premix for good. so is there a way to disconnect the oil injection system and run on a premix tank of gas to test drive the boat and check how the motor runs. I know to check the compression, L/U lube, pee stream, hull, transom, deck/floor for soft spots. i am not sure how to disconnect the injection and run it with out where the current owner would be OK with. so after all my rambling i need to know is there a way to remove it for testing?
any other advice or input on buying a used boat would be apprciated.
duff
