Its a freshwater boat, it was running hot, it just got a new (used) outdrive and this was the first time running it. I took off the hose coming into the thermostat housing from the outdrive and no water would come through it unless i put the garden hose right against the intake, forceing it through.
You should buy yourself a trunion cap with the flush fitting.
Unfortunately, it won't let you know if your impeller is working because it puts water in between the impeller and the engine.
Here is one on ebay:
http://cgi.ebay.com/ebaymotors/OMC-...002QQitemZ120109090244QQrdZ1QQsspagenameZWDVW
