Quote:
Originally Posted by sledstew
I need a control box for a 50 HP mercury, motor serial # 5864837, it currently has a quicksilver control box on it but I was wondering which other control /throttle boxes would work for this boat. Also If I take the box apart can the lever be tightened up, it wiggles out toward the seat and is really sloppy.Any help is appreciated.
Thanks
All Merc control boxes are forward and backward compatible (old ones will work with new engines, new ones will work with old engines). If you find a broken/missing part, post a photo of it and someone will (probably) give you the part number....
The loose handle sound like the retaining bolt is loose/missing. Take the control box off the panel and look at the back. In the centre of the box should be a bolt inside a recess. Is it there?
Chris.........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
