I'm looking to purchase a 1997 Rinker Captiva 192 with a 4.3l merc i/o.
I went to look at it today and I noticed that during the inspection of the engine, there was no power steering fluid in the reservior. The owner said that he usually adds some every year. I thought that the power steering system is a closed system just like an automobile.
So I looked for any obvious leaks in the engine compartment. I could not find any. I had noticed that there was some oil residue in the engine compartment and in the carpet of the water ski compartment.
The boat had gotten some water in it during outdoor storage last winter, and the bow was lower than the strern, thus causing the water to end up in the ski locker.
He said that the marina that winterized the boat, and doesn't use a pump to change the oil, he uses a special "pan" to drain the oil out. Do you think that maybe a bunch of oil was spilled during the oil change and it was not cleaned up? Then when the water got in it from the snow this winter, the oil floated to the top when it melted? Then upon draining this spring, the oil spread all over every where?
What do you think?
Thanks Morty
P.S. Don S. My uncle lives in Ketchikan, his name is Stan Berentson do you know him?
What do you think?
Thanks Morty
