engine swap
90capri
i have a 1990 bayliner 2050 capri with the 3.0, was wondering if anyone has swapped out the 3.0 to a 5.0 or a 5.7, an major issues? any help would be great thanks
Dustin
Don S
Re: engine swap
It's Merc...... Bayliner didn't use OMC in 90.
You will need a different gear ratio in the drive, exhaust Y pipe and hoses for the V8, different motor mounts. The V8 mounts to the stringers, the 3.0 mounts a cross piece on the front of the engine. So the stringers MAY be different.
The engine cover may not fit over the V8....... Too small.
Other than that, it should be easy ;)
Re: engine swap
Ayuh,..........
It Can be done,.........
But the Investment in Time, as well as Money is Usually Well Beyond Most DIYers............
