I have a '92 pro v 150 yammie, the thing runs great except at idle. It is hard to keep running when I first start it, and once warmed up, it will cut out with a sneeze at idle. Idle is set to 900 rpms out of gear. I tried raising it to 1100 rpms just as a test (no driving) and it still cut out.
Carbs were just cleaned and adjusted to specs (as far as I can). Brand new fuel tank, fuel lines, and brand new gas- have not even burned a tank yet, 5 days old.
It will cut out suddenly with a sneeze is the best I can describe. It is also a bear to keep running when you launch for the day- I wish it had a fast idle system or method.
I installed new plugs, they are BR8HS-10 instead of the normal B8HS-10 plugs- does this matter much?
Please help, docking is a total nightmare and I am afraid I may run into someones boat when I lose power.
After adjusting the timing at idle things smoothed right out, runs great now. I assume the timing was off. I just made tiny adjustments as it ran (advanced the timing arm via the screw) until it ran well.
