Hello everyone,OK,so yesterday I was out fishing for about 5 hours,the motor ran great,on the way in I opened it up a little(about 3/4's) and after about 10 second's it started coughing and sputtering,It almost acted like the choke was open.I limped it back and tied the boat up.I restarted the motor and it continued to run awfull.It will not stay running unless I play around with the throttle,and even when it is running it sounds gross.
Any ideas where to start?
thanks
Aaron
I'd start with compression, spark and fuel. Does priming the bulb while it's running make it run any better?
__________________ Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
thanks for the reply,It has a internal tank(no priming bulb),lots of spark,and although I havnt done a compression test,when I pull it, it seems strong.Is is possable that it may have sucked up a stick or dirt or something?I know this may sound silly,but I was told I probally sucked up something.
It is possible that some junk in the fuel tank came loose. What year is the motor? You may want to rebuild the carb.
