  #1
Old May 17th, 2007, 04:59 PM
Vanard Vanard is offline
Default 140 hp Mercury outboard dies when put in gear
Please help, I know absolutely nothing about boats, first one, but am wanting to learn...
So the problem is when I put the boat in gear when it's in the water it just dies. But when I'm at my house with the house it's just fine...
Any ideas on what I can do or what this is???
  #2
Old May 17th, 2007, 05:42 PM
yorkserv's Avatar
yorkserv yorkserv is offline
Send a message via AIM to yorkserv Send a message via MSN to yorkserv
Default Re: 140 hp Mercury outboard dies when put in gear
I am having the same problem with mine if you want check out the threads i posted on a similar topic i have an 88 200hp blackmax i got a couple of pointers on where to start i am working on it now if i get anywhere i will let you know
click here: http://forums.iboats.com/showthread.php?t=196259
__________________
I wish WOMEN were more like my BOAT i can get it wet when i want to!!!!!
  #3
Old May 17th, 2007, 06:34 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
no one mentioned backpressure, and lack of, if you are setting you idle on muffs, it has to be set approx 100 rpms, high, as there is no backpressure on the exhaust. then it has to the fine tuned with the motor in the water, it has to run faster out of the water to compensate for the backpressure.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old May 17th, 2007, 06:38 PM
Thx. for the link, I have replaced all of the fuel filters, fuel lines, old gas, sparkplugs, wires, and distributor cap...This thing sat for over a year before I bought it. So I did a bunch of preventative maintanance. It dies the moment I put it in gear. I can open the throttle manualy as long as it is not in gear and it's fine, but the moment it's in gear it just dies out...Any ideas???
  #5
Old May 17th, 2007, 06:40 PM
How do I go about resetting the backpressure, or adjusting it to be aroung 1,000 rpm in the water
  #6
Old May 18th, 2007, 10:01 AM
Chris1956 Chris1956 is offline
Wink Re: 140 hp Mercury outboard dies when put in gear
Vanard, What you have described is the classic example of the idle mixture being set too lean. Since these motors do not have an accelerator pump, the idle mixture needs to be richer, to compensate. You can try to richen the mixture by opening (CCW turn) the idle mixture screw 1/8 turn on the top carb (inline six, right?). Now try to accelerate. Open the mixture screw on the middle carb 1/8 turn and try to accelerate. Repeat with bottom carb, and then redo sequence (top - mid - lower) again. The idle mixture will end up being as rich as can be had, while still having a reasonable idle smoothness.
If you do not have any luck, the carbs likely need cleaning.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard 1990's model, no Forward gear MrCausey Mercury & Mariner Outboards 2 April 5th, 2007 05:47 PM
Mercury Outboard Stuck in Forward Gear jwsimp Mercury & Mariner Outboards 6 September 19th, 2006 11:25 AM
Mercury 650 - Outboard - Gear Housing addams_21 Mercury & Mariner Outboards 8 March 28th, 2005 04:57 AM
Mercury 115hp idles fine, dies when put into gear rhotec Mercury & Mariner Outboards 1 July 2nd, 2003 06:52 PM
Mercury outboard motor won't stay in gear. ljonkers Mercury & Mariner Outboards 5 January 2nd, 2003 03:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
