  #1
Old May 15th, 2007, 01:52 PM
BigEddieM37 BigEddieM37 is offline
Default Evinrude 20 HP loss of propulsion
I have what appears to be the identical loss of propulsion problem that was posted by another member in an older inquiry http://forums.iboats.com/showthread.php?t=110339 However my engine is an Evinrude 20HP from about circa 1988-ish (I don't have my manual in front of me at the moment.)
A reply to that earlier posting indicated that there might be a problem with a rubber grommet between the outer hub & prop that is slipping. I looked in both the owner's manual and service manual and can't seem to find this rubber grommet.
I've only been the owner of this engine for about 8 months now and have experienced this loss of propulsion problem at moderate to high cruise speed twice now while out on the water. Slow down, stop, pause briefly, wait, put back in gear and then it's ok again for the rest of the day. I'm worried that one time it won't fix itself and I'll be calling tow boat services. Why would this slippage, if that's what this is, be intermittent? Is there any history that this a common problem with this engine?
Suggestions appreciated.
Thanks.
  #2
Old May 15th, 2007, 02:02 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Evinrude 20 HP loss of propulsion
it's common problem with props. take a permanent marker, and draw a line, completely across the prop center metal to metal, if it is still aligned after he problem it's not the prop. this is the back side of one of my spare props, you can see the inner ring, the rubber hub, and the outer ring of the prop. the rubber lets go and slips, the slits are the thru hub exhaust.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old May 15th, 2007, 04:08 PM
Should I merely be replacing this rubber grommet on general principles since who knows when or IF it was ever done previously by the previous engine owner(s). Do I need any special tools to remove the prop and replace this rubber grommet? Is that all that should be replaced? I've never taken one apart before. I see a big nut in the center of the prop. Just hold the prop itself still and loosen the center nut with a wrench? Is that all there is to it?
Another fellow with whom I work said that cavitation could very well be what I'm experiencing. How DOES one confirm that cavitation has occured? I hear that topic mentioned as well from time to time.
  #4
Old May 15th, 2007, 07:16 PM
F_R F_R is offline
It would be unusual for the hub to slip only once then be OK the rest of the day. You are probably experiencing cavitation. You tell the difference by the process of elimination. Mark the prop as mentioned. If it's ok, it's cavitation.
Remove the prop by removing the large nut and slide it off. You cannot replace the hub by yourself, a propeller shop has to do it. But you can just replace the whole propeller.
  #5
Old May 15th, 2007, 09:30 PM
F_R,
Maybe it IS cavitation. Interesting. I will mark the prop with a marker as suggested and then look at it. Yes it DOES lose propulsion and then after slowing down to a crawl and then slowly restarting up again she's fine. Purrs like a kitty.
I'm assuming that there's really nothing I can do to remedy this cavitation thing?
Thanks for the helpful insight. I learned something.
Ed
  #6
Old May 15th, 2007, 09:38 PM
F_R F_R is offline
Cavitation is a simple thing but with many causes. The simple part is that it is an air bubble around the prop. Causes range from the motor being mounted too high on the transom, tilted too far, weeds on the lower unit, something on the boat bottom making bubbles (barnacles), and more.
Here where I live, weeds are the major problem. On some installations, a single blade of grass hooked around the gearcase can set it off.
  #7
Old May 15th, 2007, 10:00 PM
Silvertip Silvertip is offline
Just to add a bit of information. That grommet is not a grommet, its a rubber bushing that's bonded to both the propeller hub and blade area of the prop. A prop shop must make this repair which is why you can't find the "grommet".
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Unusual propulsion system Dunaruna Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 September 22nd, 2006 05:13 PM
OMC 3.0L 4Cyl -- Lost propulsion mc1711 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 May 16th, 2005 09:17 PM
Diesel/Electric propulsion...What's up with that? 12Footer Dockside Chat 11 October 19th, 2004 12:26 AM
jet propulsion setup blueovalspecial Boat Topics and Questions (not engine topics) 5 December 11th, 2002 04:28 PM
Propulsion Problem dmarsh0527 Johnson & Evinrude Outboards 5 July 7th, 2002 07:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
