Okay a couple more things to do before summer.
First I need to change engine oil and I know you can pump out thru dipstick but the pump I bought seems to be a PITA to use. I can manuever a pan below the drain plug but of course I would not be able to manuever it out without spilling. Should I drain it out the bottom of pan then pump it out of drain pan with the larger diameter tube? Also what type of motor oil? It is a '80 omc 140.
Second question, I want to do a compression test can I crank it over without hooking the muffs up. If so do you just unhook coil wire and turn engine over?
