planetexpress
- Apr 9, 2007
- 5
I had tried removing the carb drain screw last fall from my Tohatsu 5HP outboard. The brass screw head popped right off, leaving half the screw in there and a leaking carb.
I dabbed a little epoxy on the hole as a cheap fix, but now my trusty outboard is not running well. Here's what it does:
1) It will run wide open very well. No problems there.
2) When in gear and at very low "no wake" speeds, it will eventually stall, after maybe 2 minutes of operation. It starts running very roughly at the end of the 2 minutes, then stalls out. I can sometimes save it from stalling by squeezing some fuel up via the fuel line bulb hand pump and/or by putting on full choke. After stalling, it *always* starts back up if I squeeze a little up from the bulb in the fuel line, but does not start unless I do so.
Any ideas what I've done to this once very reliable little motor? Do I need to order a new carb now that I've expoxied shut the drain screw? Does this prolbem have something to do with the epoxying of the drain screw, or is it something unrelated? (I'm changing to plug now to see if that is a cause)
Thank you in advance for any help.
